I would like how to ask how you do weld evaluation in Simsolid, as I am struggling with this currently.
For example, in my test case below there is a simple weld between two beams.
When extracting the forces from this weld I get the forces in the global coordinate system.
My experience with welds is using the Eurocode standard, getting the stresses in the weld, and then make sure the stresses are ok.
If I have understood simsolid correctly the forces of the welds can only be given in the global coordinate system, leading to the eurocode method being difficult.
What is your method of ensuring the strength of welds in your models, and what tips can you provide?
Best regards.
Eskil Mellbin
