I want to set the maximum allocable RAM for a simulation, because now feko is using ju a small part of it and I want to improve it to reduce the simulation time.
Hi @Antonio Gentile ,
Normally Feko uses the entire available RAM. If this is not sufficient, the hard disk is also used (with MoM).
Do you have any indications that Feko is not using the available RAM?
Best regards,Torben
Hi @Antonio Gentile , Normally Feko uses the entire available RAM. If this is not sufficient, the hard disk is also used (with MoM). Do you have any indications that Feko is not using the available RAM? Best regards,Torben
I see now that the case is already treated in our Support.
