Hi friends,
I want to simulate a nonlinear transient thermal analysis which is coupled with mechanical support. To this aim, first I conducted a thermomechanical analysis in which the thermal load was linear and the response was reasonable.
for nonlinear analysis, I added E(T) in MATT1. I also changed the analysis to generic and added nlparm for NLHEAT analysis according to tutorials. But, I got the following error!
*** ERROR # 1461 *** in the input data:
Card 'NLPARM' is not allowed for this subcase type.
the nonlinear analysis file is attached. could you please help me to proceed with the analysis?
Note: for this model, I aimed to apply the boundary condition such that the tube is in an environment that the temperature is changing. So, I considered all the tube nodes as spcd and spc_temp with the room temperature and applied a variant thermal load. ( I hope it would be a correct way to apply the mentioned BC & load, if it is not, please give me some tip )
Thank you so much for your time and attention,
I am looking forward to hearing from you
