I have Altair Monarch and I would like to know how to convert or export files to Excel please.
Thank you,
Rabbia
Hello Rabbia,
There are quite a few articles and tutorials within the Alair Community Knowledge Base if you search "export to Excel".
For example:https://community.altair.com/community?id=kb_article&sys_id=646830791b747890c4dfdbd9dc4bcb26
Also, you can access documentation through Altair One marketplace. https://help.altair.com/2023/monarch/help/Advanced_Excel_Export_Settings.htm?rhhlterm=export excel&rhsearch=export to excel
When you say you want to convert or export files to Excel, you first need to get your data from your reports into a tabular format in Monarch and the first step is to learn how to trap the data from the resources that you are trying to convert.
Can you specify what is the source of the data that you are trying to get information from and export to Excel? (text-based report, pdf, database ...) so we can help with resources on how to get data from your sources into a table before it can be exported to Excel.
We also hold a bi-weekly webinar "Ask the Expert Series" that is also posted on the community Knowledge Based with an example of how to trap data from the report. Here is an example: https://community.altair.com/community?sys_kb_id=e6c7ad8fdb55b450e8863978f49619b4&id=kb_article_view&sysparm_rank=1&sysparm_tsqueryId=4b3b5fbc1b8f6910507ca6442a4bcb4f
Zhanna Abidor
Assuming that you have your data in a table or summary within Monarch, exporting is as easy as a right-click on the table/summary and selecting export.
If you are not at your desired table or summary, there are other easy steps that must occur.
SV
