Hello, experts.
I have been trying to create a composite laminate with several plies with Abaqus by using Hypermesh as the preprocessor. The problem is that when I try to implement the cohesive model with shell elements, it does not work. So I must use solid elements.
My geometry comes from a cut of an sphere, so it has that curvature. When I create the 2D mesh in the face, the normals are right, but when I use that 2D mesh to create the 3D one and I display the element axes, they are wrong oriented and the local z does not correspond with a normal of the face.
Due to this issue I cannot implement the cohesive model correctly.
Any ideas?
Thank you.
