Hello!
When I try to post-process the results of an Acusolve simulation, transferring the results to run in Abaqus other analysis, with acuOdb, at a certain moment it says: 'This model contains an element type that is not yet supported: UNDEFINED. The requested process requires that all element types in the model be supported'.
The Acusolve simulation is correct, so it makes me wonder if some element types of this solver are not compatible with Abaqus.
Any solution for this?
Thank you.
