Hi experts
I get an error message I don't understand. I'm doing a frequency response (Sine) analysis, and I gert this:
*** ERROR # 4844 *** BASELINE -1093659375 in subcase 6: At least 3 acceleration points are expected.
Any??
Can you share the .out file?
And also explain what you are trying to do, please.
Hi Adriano
I'm attemting to do a frequency response analysis to see how the structure with its natural frequencies respond to a sine input.
I define several loadcases.
Subcase 1 is a static pressure load to be used as a preload for normal modes analysis
Subcase 2 is a Normal M;odes analysis wirh preload from Subcase 1 ( STATSUB(PRELOAD) = 1
Subcase 3 is the frequency Response analysis where I also get this error message.
