Hi all
I need to get the Mass Properties (CoG,MoI) for my Model in tabular form in my out file. I also need the effective mass for each mode in a tabular form. How do I get these tables in my Optistruct .out file. Thank you for any help:-)
effective mass is output using PARAM,EFFMASS or something like this.
It will write mass participation in your .out file and in some other auxiliary file that I can't remember the name right now.
Mass and CoG I can't recall from the top pof my head, but certainly you can, by using some PARAM card, i think.
effective mass is output using PARAM,EFFMASS or something like this. It will write mass participation in your .out file and in some other auxiliary file that I can't remember the name right now. Mass and CoG I can't recall from the top pof my head, but certainly you can, by using some PARAM card, i think.
WEIGHTCHECK
Subcase Information Entry Used to give a report of the mass properties of entire model, including weight, mass moment of inertia and the center of mass.
WEIGHTCHECK(print,grid,set) = option
