Hi
I'm diving into RADIOSS.
I have to do an Impact/Crash analysis, so I'm going through some tutorials as a starter. In the tutorial:
RD-3050: Simplified Car Pole Impact in HyperCrash
https://2017.help.altair.com/2017/hwsolvers/hwsolvers.htm?simplified_car_pole_hc.htm, but my setup does not give the same input possibilities as the Tutorial show.
Is it different versions? Is it different Set-Ups?
For example, when creating a rigid wall, the Tutorial tells me to define M0 and M1
When I do it, I get the following:
Where should I enter M0 and M1?
Also, I don’t get a new popup Window, only a possibility to enter on the screen.
I’m stuck! Any help would be appreciated.
Rgds Bernt
