I simulated bending of a sheet metal and now I want to use this deformed sheet metal in a subsequent simulation and bend it again with another tool, which means I need the geometry as well as the residual stresses and strains, which remain after the first simulation. Which is the proper way to do this in Optistruct?
I can import the deformed geometry from Hyperview. To get the stresses and strains, do I have to use the "field" card using the h3d file as input or is there another way to do this?
Thank you very much in advance.
