Seeing all s1.h3d files of optimization runs together
After completing the optimization, there are 50 runs due to the algorithm and inside all of the runs there are s1.h3d files where I can see the results of each evaluation and I can add results manually in hyperview but for more evaluations it is quite a hard job to do.
So I wanted to ask if there is an easier or automatized way to see all s1.h3d files of runs together in hyperview?
thank you
yes I am using that one but as there is many results it is kind of a long process, I want to know if there is an easier way?
Thank you
0 -
Hi Cemreyvz,
You can use HvTrans to merge multiple result files. Please refer the below video, (merging starts from 4:00)
https://altairuniversity.com/learning-library/convert-result-files-with-hvtrans/
Livil Lyle
0 -
oh thank you Livil Lyle /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
