Hey,
I'm trying import the surface Mesh(*.Nas) from HyperMesh into AcuSolve and getting an error as below. Where am I going wrong ?
Best regards
Nevin
Are you exporting using CFD (AcuSolve) profile and the format Natran Fluent ?
Can you post a screenshot of the folder where the .ACS file is ? Is there a meshintersections.dat file?
Yes , i am trying to export with Nastran(Fluent) Standart Format. There is a mesintersections.dat. You can see on the images.
Please import the mesh_intersections.nas in HyperMesh. This will give you an idea of where the problem region is this. As the name tells, there are intersecting elements in this region.
it worked, thanks a lot /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
