What is an Engine file on Radioss?
Hi vishruthdilip
Engine file in Radioss is an ASCII file that contains various run controls for the simulation. It contains the details such as run time, time history and animation plotting frequency, output requests etc.
Check this video from Learning library for detailed information on Radioss engine file
https://altairuniversity.com/learning-library/2-guidelines-to-create-engine-file-for-radioss/
