I am trying to understand what S-Foundation is doing when you say a footing is rigid versus flexible. To this end, I have a simple 5m x 5m x 1m (thick) footing as shown in my attachment subjected to 1072 kN force. I run a linear static analysis with both flexible and rigid options. For the flexible case, I have set the modulus of subgrade reaction to 3300 kPa/m. As shown in my attachment (Capture1), the flexure and one way shear demand on the footing in the flexible case is about twice that for the rigid case. I also find that the one way shear capacity for the flexible case is about two times lower than the rigid case.
How is S-Foundation calculating the one-way shear demand and capacity on a flexible footing? It seems to me that it is using some reduced width or depth. Why is the flexure demand also doubled?
