Hello Support Team:
I am checking a steel frame using S-Steel, following the video posted on Youtube.
When I tried to select the Code Check button, I received a message telling me, "at least one member has to be selected".
Using the select window or the select all button, I apply select all: but nothing happens. The model is not selected, so I cannot go forward.
Am I missing any step in the process?
This is the first time I am using S-Frame version 2022.2 which includes S-Steel.
Thank you for your help.
