DLL Block error : File not found *.dll...
When the inverter circuit using the DLL block is simulated, an error occurs with the message below.
"File not found."
<File Name>.dll
There seems to be no problem with the file name or path setting.
There is no problem in PSIM legacy version, 9.14, But latest version 2023 had a problem.
Visual Studio was installed in the same version, but an error occurred.
I want to know what the cause is.
