Hi, I don't understand the SN and EN curve.
SN case
if i put a Yield strenght of 290 and i click estimate the curve from UTS, at 10^3 cycles the curve shows me a value of 800MPA, How it is possible that has a value greater than the static value?
Thanks
Hello Nicolò,
Unless specified otherwise (there is a parameter for that), curves for fatigue material are defined in stress range, not stress amplitude.
And Stress range = 2 x stress amplitude.
On your picture we see a stress range of about 520MPa (the 800MPa is the extrapolation at 1 cycle).
Gildas
