I'm new in Altair Hypermesh and I'm doing a thermal analysis of an electrospindle.
I have to analyze the grid temeperatures in the following case:
There is a bearing in one extrem of the spindle and another one in the other extreme. They generate a constant heat flux, but with a different value. Besides, the electric motor is another heat source.
With the aim of evacuate the heat, I apply a negative flux in housing's Surface.
The problem is that I want to do a heat transient analysis, in which the negative flux is always active, but the bearing's and the motor's fluxes are disabled when 10 minutes have been passed.
Anyone knows how I can introduce a flux that depends of the time?
Greetings,
DavidSol.
