   I made the geometry for a single-phase transformer on Flux2D. I know the values of the current and the voltage that I am supposed to have  in the stator and the rotor during an open circuit test, and also the phase difference and the transformation ratio. And I would like to see if I get the same results with the software. The stator is on the left of the picture. On the right, there is the rotor with an infinite resistance. Since I know the transformation ratio, I know the value and the phase of the voltage to put in the software. But I don't know if it's the way to do on Flux2D. When you create the circuit, where do you indicate the mutual inductance between the rotor and stator ?
   Thank you in advance!
