I am testing my model with FIALA tires for some turning cases. I notice something I cannot explain.
I set a relatively high steer angle to see the Fy generated by tires when slip angle is more than the critical value.
I compared the Fy force I get from the output with mu * vertical force.
Considering I have a max mu of 0.8, I get a Fy which is 0.83 times the vertical force.
As example: The red line if the Fy force generated by the tire (from the autotire ouput in C-axis system). The blu curve is my user defined output taking 0.8 * vertical force (from {ts_18.sys_varsub.sv_cp_force_z.VARVAL}).
How is this possibile?
The force should be:
I set Fyc (CGAMMA in tir file) to zero.
