In the latest release, constraint entities for coupling kinematic/distributing were implemented for Abaqus profile. (the earlier RBE2/RBE3 elements)
Any old RBE2/RBE3s are automatically converted to this new entity when opening from an older version. This new representation makes sense from a graphical and user friendliness standpoint in defining DOFs, properties, etc, but I fail to do some things with them that I used to be able to with the RBE2/RBE3 elements.
- Equivalencing does not take coupling constraints into account. Especially for legacy models, this is quite a big handicap.
- How do I mirror constraints? If not possible, this is a big handicap when wanting to mirror an entire model model. Previously, could just select all elements, mirror, and all RBE2/RBE3s would be mirrored as well, and still be attached to the relevant nodes/elements. Now this is no longer possible.
- With the new constraint entities, what's the recommended way to mirror a model containing elements/coupling constraints?
Eli
