Pothole Modeling - Cleat along the road direction
Joel Purtschert
Joel Purtschert Altair Community Member
edited 2023 15 in Community Q&A
Hi!
I am modeling a car. It accelerates straight to a given velocity, then changes the lane and drives straight on the other lane.
Furthermore, I want to simulate a load case, where a cleat is between the lanes, eg. not perpendicular to the road, and the effect that has on my car.
Now I'm using the auto tire feature using a default tire. Additionally, I model the road with the default Cleat10x50mm_45deg.rdf file, where the cleat is at 45° to the direction of travel, which works fine. If I change the parameter ($ deg of rotation of the cleat about the Z-axis wrt to the X-axis of the road) to 90°, it should be along the direction of travel.
However, if I simulate the car with the cleat at 90°, the results are the same as if I have the cleat at 0° (perpendicular to road).
Has anyone an Idea on how to tackle this?
- Cleat along the direction of travel, such that it is driven over during a lane change?
- How to show this cleat in motion view road graphics?
Please find attached a small drawing of the situation.
Thanks in advance for your help!
Cheers
