I'm currently studying the losses of a ring core, with isotropic Fe-Si material, in Flux 2D.
I wanted to compare the results given by two ways :
- with the loss computation module included in Flux.
- with a custom computation with Matlab or Octave (after extracting flux density values in face elements in Flux)
I'm worrying about my computation method, because they don't give the same results :
| Global flux density | 0.36T | 0.90T |
| Losses : Flux | 0.650 W | 3.038 W |
| Losses : Matlab/Octave | 0.586 W | 2.734 W |
I don't know why there would be such differences between the losses of these two means of computation, as the local flux density is the same, we use a NO material, the Bertotti parameters are the same between Flux and Matlab...
Is it coming from flux density values I'm using to compute Matlab losses (I'm using Mod(B)) ? From my Matlab code ?
If you need, more precise information is included in joint files to this post.
Thank you for your help,
Ronan Corin
