I have set up a tablest for multiple temperature stress vs. strain curves in a nonlinear static analysis. The analysis has run previously. I see in the knowledge base that this was requested and followed the example given. When I run the analysis I get an error :
I did not see the resolution to this error in the knowledge base .
Thank you
Chris Thorpe
