Im attaching the .rad and .out file.
these are the errors:
ERROR ID : 179 ** ERROR IN PART DEFINITION (MATERIAL) DESCRIPTION : -- PART ID : 24 -- PART TITLE : COMP-PSOLID_24 MATERIAL ID=0 DOES NOT EXIST
No material was defined for components ID 24, 25 and 26.
ERROR ID : 1109 ** ERROR IN TH DESCRIPTION : -- THGROUP ID : 1 -- THGROUP TITLE : RAIL NO TH VARIABLE DEFINED
There is no variable defined for output request. The default output requests are defined by entering DEF in the Data: Var table.
