I have done Non linear pretension analysis of a gasket. I would like to check Contact pressure on gasket
In Hyperview results contour I found 2 things
1.Contact Normal/Traction pressure ( around 180 Mpa)
2.Gasket thickness direction pressure ( around 70 Mpa)
these two contours have different magnitudes in pressure.
My question is which pressure should I consider for validation?
Cross section View of Model
