I am doing Non linear analysis.it is a quite big file..while doing the analysis suddenly the PC was shut down.Let us suppose any option to restart the solution file from where it is stopped?
Refer Tip and Trick 1332 of December 2018.
https://insider.altairhyperworks.com/december-2018-tips-tricks/
Where we will find this entries in Optistruct?...in optistruct file manager i found only 'RESTART' Append option
Analysis : Control cards
