I am running NON linear Analysis..Which Card should i use? ....I want to visualize % load in Hyper view results using optistruct as a Solver
10% of load
20% of load
... like this
In ABAQUS we use 'TIME POINTS' card...But in Optistruct which card ?
Time point output is not available yet but the output is available for every converged increments by default when NLOUT is present in the deck.You can also look at NLADAPT card to restrict the increment size and have more number of outputs.
