I simulated a FRF Analysis..Below files formats are generated ...I tried to open .disp ,....file but it doesnt show any results..while file should i use to open the results in Hypergraph...if the file is not generated while format should request..
You can try other output format like .pch or .op2. Those file types could be read by HyperGraph
