I calculated the efficiency map within FeMT. However, the results seem to be imperfect. Because the machine_Efficiency text file indicated that after 2000 rpm, the computed efficiency is shown as Nan. Where is my fault?
it should be noted that the nominal and maximum motor speed are 1500 and 4500 rpm, respectively.
Does determining the maximum phase current and voltage (rms) affect this fault? The nominal phase current and phase voltage of considered motor are 100.5 amp and 49v rms, respectively. In the e-Machine toolbox, what value should I enter for max phase current and max phase voltage (rms)?
