Hi!
I have a question. If one uses for example two .stmod files or one .stmod and .hm file for one entry, should I submit on the .zip all files used?
Thank you.
If you utilize two .stmod files or a combination of one .stmod and one .hm file for your entry, you should consolidate all the files used and submit them in a .zip format for the contest.
Kindly upload your final entry for the contest through the following link: https://web.altair.com/global-student-contest-2023-rules-and-submission.
All the best for your submission!
