I am currently simulating a full bridge LLC converter with PSIM.
Boundary conditions:
300 - 500V input voltage
Nominal input voltage 400V
Output voltage 50V
output power 3,4kW
Frequency 200kHz
for Q I have determined 0,5 and for k a value of 4 as optimum.
Now I would simulate the whole thing with the losses and then determine the efficiency of the converter.
With the help of the page: https://powersimtech.com/resources/application-notes/power-loss-and-efficiency-calculation-of-resonant-llc-converter/
a loss determination with a LLC converter was already explained. First a full bridge LLC converter was simulated and then the losses were determined in another model. However, as can be seen in Figure 8, this is a half bridge and not a full bridge. Is this contribution therefore wrong?
Are there any prefabricated models with a full bridge in which the losses were also determined?
