Dear EDEM community,Is it possible to feed EDEM parameters (such as sliding and rolling friction) automatically using a Python script and without the need to open the software and use the user interface?Thanks for your help in advance!
Hi Ahmed,
There are a series of EDEMpy 'set' functions including the friction.
If you to go the Altair 2022.3 install folder > \EDEM\EDEMpy\help > Index.html > Module Index > edempy.creatorData.Mateirals the functions are detailed there.
The e-learning details an older version of EDEMpy so the functions have changed however it gives you an overview of EDEMpy.
https://learn.altair.com/enrol/index.php?id=228
Regards
Stephen
Hi Ahmed, There are a series of EDEMpy 'set' functions including the friction. If you to go the Altair 2022.3 install folder > \EDEM\EDEMpy\help > Index.html > Module Index > edempy.creatorData.Mateirals the functions are detailed there. The e-learning details an older version of EDEMpy so the functions have changed however it gives you an overview of EDEMpy. https://learn.altair.com/enrol/index.php?id=228 Regards Stephen
Many thanks, Stephen!
