the order of contacting
I used non-linear transient analysis to know contact force between two objects.
In post porocessing , I want to know the order of contacting part.
for example,
0.001s contact element 228602
0.003s contact element 225841
How do I know the order contacting each point?
try CONTPRM,CONTGAP,YES and GAPPRM,HMGAPST,YES
0 -
Thank you,
Now I'm trying by adding like that card.
0 -
There is something wrong.
*** FATAL ERROR # 8111 ***
vfileio:: Failed write for file[2], i/o 16384/0,
name=C:/Users/nFukata/Desktop/Zhao san/model03_r4_6060_02.rs~.
This is likely caused by insufficient disk space.
What is this error?
0 -
Looks like there is not enough space available.
Can you change the working directory and check if that helps?
Please share the .out file if that ain't help
0 -
HI,
The problem is with the disc space.
Please use TMPDIR to allow solver write scratch files in a different bigger directory.
0 -
Hello
The calculation was done, CONTPRM,CONTGAP,YES and GAPPRM,HMGAPST,YES
so how to check the contacting in Hyperview?
0 -
Please check the .cntgap.file which will be written in your working directory.
0 -
Thank you for your reply.
I can't find the cntgap.file, the working directory is same as hm file, outfile...?
