memory problem
User: "VAL1"
Altair Community Member
Updated by VAL1
Which parameter should be changed?
*** ERROR # 381 ***
  Allocated working storage insufficient.
  Available memory = 2157 MB.
  Required memory = 3548 MB.
  Number of vectors in modal space = 5628.
  Number of eigenvectors = 6.
  Specifying number of modes in EIGRL card of modal subcase may solve
  this issue. Or, set param NUMEG to a value higher than the number of
  vectors in modal space.
1 - 8 of 81
    User: "Altair Forum User"
    Updated by Altair Forum User
    You can either reduce the number of modes on EIGRL card or go to control cards>> PARAM>>NUMEG and specify a number higher than 1000
    User: "VAL1"
    OP
    Updated by VAL1
    Thank you
    I changed  number of modes on EIGRL from 6 to 3.
    set param NUMEG to 6000
    but same error happened.
     *** ERROR # 381 ***
     Required memory = 3546 MB.
     Number of vectors in modal space = 5625.
     Number of eigenvectors = 3.
    Hi @naoki
    Is it possible to share the model file?
    Please use the file transfer link in my signature to share the model file
    Can you add SYSTETTING(MINLEN=5000) and check if that helps at your end?
    I am able to run the model on my machine with MINLEN of 5000
    User: "VAL1"
    OP
    Updated by VAL1
    I cannot find MINLEN in SYSSETTING card.
    So where should I see? same as OS_RAM_INIT?
    If I change memory size,  Required memory is increasing.
     *** ERROR # 381 ***
     Available memory = 4820 MB.
     Required memory = 6530 MB.
     Number of vectors in modal space = 7636.
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    @naoki: How about your hardware? RAM? How many nodes/elems?
     *** ERROR # 381 ***
    You can add MINLEN in .fem file. Open the .fem file in any text editor and add the same. I will share the file with you for reference.
    User: "VAL1"
    OP
    Updated by VAL1
    Hello, Prakash san
    It could be solved when I added MINLEN=5000 in .fem file directly.
    Thank you so much!
