press model analysis by Non linear quisi-static
VAL1
VAL1 Altair Community Member
I'd like to analysis using distorted model (attached file).
make this model transform to plane like pressed,
and want to calculate how much force is applied.
I set contact surface use another two plane object upper side and lower side,
but this analysis didn't convergent.
How should I do?
(this attached image is exaggeration. actual distortion is 0.5mm)
  • Altair Forum User
    Altair Forum User
    edited November 2018
    Hi @naoki
    Could you share the model file to my dropbox link, please?
  • Altair Forum User
    Altair Forum User
    @naoki
    Thank you. I have the files. I will check and update you soon.
  • VAL1
    Thank you.
    I have one more question about contact surface.
    What is the difference between FINITE and CONSLI option in Contact Group?
  • Altair Forum User
    Altair Forum User
    HI,
    Now I changed the contact from PCONT to SLIDE and with S2S and I see the progress. But the results are yet to come out.
    FINITE sliding searches contact for every load increment but with continuous sliding, the search is conducted for every iteration. CONSLI provides better convergence when large sliding is present in the model.
  • Altair Forum User
    Altair Forum User
    you can try to use radioss quasi-static. to my mind radioss is better for contact ussues;)
  • VAL1
    Thank you, I haven't used Radioss before,
    Could you give me an advice how to set up with Radioss same as optistruct contact analysis ?
  • Altair Forum User
    Altair Forum User
    Hi @VAL1
    The model didn't converge at my end and I see a lot of element distortion at the end(till 99% converged). I will check if this has anything to do with the material.
    There are several tutorial available in RADIOSS for example RD-T: 3595 Three Point Bending with HyperMesh
  • VAL1
    Hello , Prakash san
    Thank you for information , I try to use Radioss with RD-T: 3595.
    by the way If possible, could you give me the 99% converged result?
    And I couldn't download RD-T: 3595 sample from website, Could you share it?
  • Altair Forum User
    Altair Forum User
    Hi @VAL1
    I have shared the modified file with you and here is the RADIOSS file
