I'd like to do freq resp simulation but Estimated Scratch Disk Space is too large.
How should I reduce this size?
Hi @naoki
Please refer to this:
Thank you ,
it was solved by changing mesh size with 'agressive' to reduce element
and deploy temporary disk amount as you mention.
Parakash san,
this is a trivial thing but I want to display mass with review function,
the mass value is small so it couldn't display, only 0.000,
how do I change the decimal point?
I think it is possible,
I will check and will update you soon,
