To be accurate, Material's Young modulus is different according to pressing and pulling.
Can I set the two value for 1 material?
Hi VAL1
It is possible if you use an orthotropic material card.
According to online help MAT 3 has the capability to apply youngs modulus in different directions.
Have a check at the different card capabilities from the online help
Thank you!
I can use Mat3 for orthotropic material.
But I mean the attached file. in case of Al, If it is stretched 73GPa, pressing 71GPa.
what card should I use in this situation?
Hello VAL1,
If you performing simple tension & compression individually, you can create two material with different E value. Make two prop & two loadstep.
