Hello AcuSolver Users,
I got a problem with plotting out a radiative heat flux in my 3D model. I set up all boundary conditions within the model, tried to defined FSI as walls with radiation option, picked emissivity model, laminar flow and DO solver, but after calculations I cannot see nowhere the radiative and total heat flux densities... neither in HyperView nor AcuFieldView.
Attaching simple scheme of my model.
From the top, the boundary conditions are: top surface (radiation wall with fixed temeprature), solid (cannot define any radiation properties here), fluid (air), solid, bottom surface (radiation wall with zero heat flux).
Could you please tell me if I model it well? And how to plot aforementioned variables?
Best,
Jan
