Hi, I was trying to understand the particle replacement tutorial. When I try to create a .dll file in Visual studio 2022, it gives error E0413 and E0140 on line 163 in Cremoval.cpp. Despite trying all versions I get the same result. How can I solve this?
Hi Sevgi
From your image, it seems like you are using an older version of the tutorial (NExternalForceTypesV3_0_0). Would you be able to try downloading the newer version and see if the behavior persists.
