I need to perform Kinematic and dynamic analysis of a Non-Circular Sprocket Chain Conveyor system using MotionSolve\MotionView. The system consist of a driving sprocket, an idler sprocket, a non-circular idler sprocket and conveyor chain as shown in rough figure of cross-section of conveyor belt. The conveyor is slacking on lower span, as the conveyor is sufficiently large for non circular sprocket to move at all conditions. The conveyor moves with a periodic to and fro motion between two extreme positions related to non-circular sprocket(elliptical pitch curve) orientation.
A real life example of such sprocket-chain conveyor
.jpeg)
There are following things that I wanted to know as I am new on this platform and I will be really grateful for the related guidance given to me.
- Is there a dedicated module(or wizard) to model a Sprocket Chain Drive\Conveyor in MotionSolve\MotionView or any altair software?
- What must be the Constraints(or joints) and inputs that I must use for simulation and analysis of the Chain Conveyor?
- Is there a dedicated module for modelling a Non-Circular Sprocket in any altair software?
- Am I using the correct software and procedure for solving the stated problem?
Thank you for your reply.
