I am trying to simulate a model on AcuSolve in hyperworks and when i try to run solver the Solver exec dir is missing. I have attached a pic for your reference. Please help me with this.
Hi Rahul,
You can manually enter the location of bin folder of AcuSolve installation.
C:\Program Files\Altair\2017.3\acusolve\win64\bin
It's better use:
C:/Program Files/Altair/2017.3/acusolve/win64/bin
I am getting this error -
You probably need to adapt the path to your particular installation.
Could you post a screenshot of the path you have in your Solver launch path.
i have the same problem.
You can export the model with 'Export Solver Deck'. After that you open AcuConsole, import the model and solve it there.
Now, I am getting this error -
Your installation is not complet.
