I am Working modal analysis, i found my model is over deflecting it is of steel. Steel component won't deflect like rubber. It is assembly of 30 components max steel, ADC material is used.
Thanks in advance
did you solve eigenfrequency?
in frequency/modal analysis displacement/stress doesn't matter.
could your explain what did you do? and show, please, your result pics.
thanks for your reply,
I have solved the eigenfrequency
Frequency is starting from 3000 Hz
thanks for your reply, I have solved the eigenfrequency Frequency is starting from 3000 Hz
Displacements in the modal analysis may not be relevant, they are not relative.
