🎉Community Raffle - Win $25
Join and Win
how to get torque as an output as result
User: "Teja_21569"
Altair Community Member
Updated by Teja_21569
hello,
I am working on model of pressure plate which have axis offset. A shaft passes through it. when pressure applied (in x-y) on the pressure plate due to the offset one side of pressure plate will have more pressure. Which causes rotation on around z axis. As the shaft passes through z-axis. Shaft and pressure plate are in contact.. As pressure plate will rotate it will tend to rotate the shaft. I want to find out for particular pressure how munch is torque is generated.
i want to get torque as output when pressure is applied. how to get torque as direct output
1 - 1 of 11
