Receiving the following error when launching Ramdo on LINUX.
error while loading shared libraries: libmwlaunchermain.so: cannot open shared object file: No such file or directory
Please make sure you are installing RAMDO on a supported platform, and that the required libraries and drivers are installed on the platform before you install RAMDO. Additionally, while installing, make sure you are using the required user privileges, so you don't run into permissions issues.
Detailed information should be available with the release notes and the installation instructions.
