In CADFEKO, I place two far-field requests:
(a) phi = 0 degrees and theta ranges from -180 to 0 degrees in 1-degree increments
(b) theta = -90 degrees and phi ranges from -90 to 90 in 1-degree increments.
For theta = -90 degrees and phi = 0 degrees, there are then two far-field data sets in the FEKO .out file. One is from (a) above and the other is from (b) above. As copied from the FEKO .out file, the magnitudes and phases from both (a) and (b) are indicated below, where one line shows results from (a), and another line shows results from (b).
LOCATION ETHETA EPHI directivity in dB POLARISATION
THETA PHI magn. phase magn. phase vert. horiz. total axial r. angle direction
-90.00 0.00 8.313E+01 157.06 4.970E+00 -105.84 15.2200 -9.2473 15.2355 0.0593 179.57 LEFT
-90.00 0.00 8.313E+01 9.84 4.970E+00 106.95 15.2200 -9.2473 15.2355 0.0593 -0.43 LEFT
The magnitude of ETHETA from (a) is identical to that from (b). The magnitude of EPHI from (a) is identical to that from (b). However, the phase of ETHETA from (a) differs significantly from that of (b). Additionally, the phase of EPHI from (a) differs significantly from that of (b). It does not make sense to me that the results from (a) should be significantly different from those from (b). Which set of results are correct? Any insight that could be provided would be highly valued.
Michael
