Dear Altair support team,
I am setting up the analysis of the crashbox for optimization.
I have some questions regarding the Hyperstudy,
1. As figure below, can I set the position of those handles (red points) as a design variables because I need to find out the optimal taper angle. When I looked into the .tpl file, there cannot be adjusted them while shell thickness can be specified the lower upper bound directly.
If impossible, could you suggest me the similar ways to carry out this task.
2. When I Evaluate Tasks for both nominal run and optimization. I think, the software is trying to solve the results but unfortunately when I look into the CPU load, it just 9% as same as the memory, completely different from usual situations. Normally, I define number of CPU cores as 24 (-nt 24) in RADIOSS.
There have something wrong? or how I can define the core number in Hyperstudy? it is very slow now even a small problem.
thank you for your help,
best regards
Wisawanart
