I am doing 3D analysis to find eddy current loss in PM of high speed motor.
Is there any way to display current lines in the permanent magnet just like the flux lines stator or rotor core?
Hello Hamid;As i answered you from the support, displaying isolines of eddy current is not possible, but you can display the arrows of Eddy current on the volume region defined as solid conductor.You can also display iso values of Eddy current on the volume region, or on cut planes.Best regards
Thank you for your kind response.
I have responded there to your message.
