I am solving a model with Contact non linearity in Optistruct 2019
Getting below syntax error message; while using SMOOTH contact interface parameter.
Any insights?
this looks strange.
Does changing to SMOOTH, MAIN, ALL help?
can you share the whole contact definition here?
Open your fem file and copy and paste the CONTACT specified in the error message.
I don't remember when SMOOTH was added, but I believe 2019 should be ok for using this.
Hi Adriano,
Thank you for the reply.
I tried with SMOOTH,MAIN,ALL as well.
But same error appeared.
Here is the contact definition.
