How to change calibration file directory
User: "chongjun"
Altair Community Member
Updated by chongjun
Currently i am facing issues of calibration file being stored in a default directory that i have no access to, causing multiple simulation issues.
May i know how to change the default directory, i have tried changing the start in from properties in inspire shortcut but it does not seem to work.
1 - 2 of 21
    User: "SungMoonKim"
    Updated by SungMoonKim
    Hello Chongjun Wong
    I've checked calibration path both Inspire Print3D 2023 and Inspire Print3D 2024.
    The picture below is what I checked.
    There are two ways you can proceed in the current situation.
    1. Change the security settings for your equipment through an IT representative.
    2. Using Inspire Print3D 2023.
    I hope you get good results with Inspire Print3D.
    Thank you and Best Regards,
    Sung-Moon Kim
    User: "chongjun"
    OP
    Updated by chongjun
    Thank you for the assistance
